May 7, 2002, 05:49 |
Linux optimization for FLUENT
Hello everybody,
I would like to ask you, is there any linux software optimized for FLUENT? How can I optimize linux for run FLUENT calculations? Where can I find something to do this? My problem is that this pc, which I use to calculations has RedHat 6.2 and FLUENT 5.5.14. These two programs don't work as I expected at the begining. Regards Jacek |
May 7, 2002, 06:03 |
Re: Linux optimization for FLUENT
I'm running Fluent_6.0 on RedHat7.2. Fluent is running very well. I do not have any problems. Maybe you need to migrate to Fluent6. Regrds |
May 13, 2002, 04:21 |
It should be OK.
May 13, 2002, 04:33 |
Thank you,
I will try. But maybe Debian is better than RedHat 7.2? Jacek |
May 18, 2002, 15:52 |
Linux is ok. The question is: Is Fluent compiled with the intel-compiler or with gcc ?
May 19, 2002, 05:20 |
I have no idea about compiler. What does mean gcc? I am planning to buy new pc mashine based on Athlon processors. Is it good way of thinking? Maybe they will work better than Pentium III 733 MHz, hope. Regards Jacek |
May 20, 2002, 17:19 |
Here have been some discussions about Atlons ans P4. Look for them. I`d prefer P4 >2GHz with rdram. What about the new 64bit cpu from Intel (I forgot the name..) ? benchmarks ?
May 21, 2002, 04:30 |
I'm using Redhat 7.1 with Fluent 6.0. I've found that Fluent 5.5 doesn't like the glibcc version in 7.1, so this doesn't work properly with the gui. Fluent 6.0 has no such problems.
regarding compiling - I just use the standard make file and that works fine. I imagine it uses gcc as the compiler but haven't checked. I have noticed that Fluent tends to run a bit slower if you use compiled udfs rather than inbuilt Fluent routines. For example when I use a udf to calculate an ideal gas density (same as Fluent) it seems to run a bit slower than the inbuilt model. I haven't done a rigourous comparison, but it seems a bit slower - which suggests the use of shared libraries etc may not be optimised during the compilation. The differences however are small and I doubt its worth worrying about too much. Choosing the right models and setting up your problems etc is probably a better use of available time. Greg |
May 23, 2002, 02:19 |
#9 |
Yes, the udf's use gcc. But is it possible, that the fluent-code is compiled with other compilers ? Intels own c-compiler seems to produce faster code (10-30% I heard somewhere.. ?)
There had been a change of the glibc in suse 7.1 to 7.2 . I also found, that the memory-requirements and the speed also depend on the nonconformal interfaces (I often have them). The best way to get faster is: bay a new cpu |
May 23, 2002, 03:11 |
#10 |
I'm not sure of any of these details. I suppose you can ask Fluent, though I'm not sure whether there's much point.
Speedup of 10-20% really isn't that much is it. I doubt whether its worth worrying about, given all the other costs and factors etc with modelling. Greg |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
How to install linux? | gholamghar | Main CFD Forum | 3 | July 22, 2010 10:40 |
FLUENT in Linux | L3munoz | Hardware | 4 | October 29, 2009 04:58 |
Install Fluent in Linux | L3munoz | FLUENT | 0 | July 21, 2009 14:55 |
Linux to Windows (dual boot system) | Alex | Main CFD Forum | 9 | May 3, 2007 03:36 |
