Disaster tent-FIDAP model
Old   May 28, 2002, 11:45
Default Disaster tent-FIDAP model
Andrew Parker
Dear all
I am trying to model a design I have for a disaster shelter for natural disasters. I have used Fluent and Gambit before, but I have never used FIDAP. I am using WIN 2000, and I am finding it hard to start the gui program. I need some general starters tips for FIDAP, including starting the program and information on modelling. I think this would be a great use of Fluent's fluid-structure interaction program, as new, and good disaster shelters a drastically needed.
Cheers again
Andy
Old   May 29, 2002, 11:00
Default Re: Disaster tent-FIDAP model
jwt
You first need exceed6.2 ,then read chapter 2 or 3 in the Fidap user manual which will tell you how to start GUI program. Good luck
Old   May 29, 2002, 12:07
Andrew Parker
I have read this but I do not know which commands to type into the command prompt to get it to work.
Andy
Old   May 30, 2002, 10:31
jwt
1 edit a *.bat file ,included command as follow:
set FLEX_LM_LICENSE=c:\Fluent.inc\license\license.dat fidap -id example -g
2 save this file to your working directory.
3 add a shortcut in your desktop.
4 double click the shortcut.
Old   June 3, 2002, 18:04
Jaydeep Kulkarni
Unlike Fluent, Fidap cannot be started from the "Start" menu. It must be started from the command line. So, just open a Command Prompt window and type in:
> fidap -id test -gui
Provided that you have installed Fidap correctly and the license manager is working ok, you should see Fidap GUI coming up.
If you have never used Fidap, then you may want to attend an introductory course, since Fidap GUI is completely different than Fluent GUI.
As far as modeling goes, have a look at the balloon expansion problem in Fidap 8.6 Update manual.
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 04:43
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
