May 19, 2002, 10:52 |
Postprcess of FIDAP
I had done a caculation of flexible pipe, and want to show the distortion result of pipe in the FIPOST. How to do it? Please detail.
June 3, 2002, 18:09 |
Re: Postprcess of FIDAP
You can use the command "mesh" to see the distorted mesh or use contour(dx/dy/dz) commands to plot the contours. If the problem is transient, then you can issue the "movie" command followed by one of the above commands.
June 5, 2002, 04:03 |
Dear Jayk: Thank you for your reply.I had seen my result use your method,but the meshs were distorted too much.I tried to change several scale factor,but no any change in the mesh window.Do you know how to do ? Thank you in advance jwt
June 10, 2002, 14:09 |
click 'View', then click 'Pan/Zoom'.
June 12, 2002, 20:01 |
Wonder if any knows how to postprocess the time avareged pressure coeff obtained using a transient simulation for a flow past cylinder. thanks
Fidap to Fluent | Ravi | FLUENT | 3 | July 10, 2008 13:31 |
user_sub FIDAP doesnt work | semetay | FLUENT | 3 | July 22, 2006 19:51 |
2D Transient flow using Fidap | Young | FLUENT | 1 | July 2, 2004 12:02 |
2D Transient flow using Fidap | Young | FLUENT | 0 | July 1, 2004 00:26 |
Variable Density - Free Surface with FIDAP | Vitaliy Pavlyk | FLUENT | 7 | May 2, 2000 15:56 |
