Solution Diverges while Parallel Processing
Old   June 30, 2002, 22:08
Default Solution Diverges while Parallel Processing
Prateep Chatterjee
I'm running a single-step chemistry, DO radiation modeling, laminar reacting flow case. when I run the job interactively, I don't have any convergence problems. the moment I switch to the parallel solver (6 processors on an SGI Origin 2000 running irix 6.2: background job using the QSUB batch scheduler), the solution diverges.
initially I thought I had very high energy and density relaxation factors, but changing any of the relaxation factors (pressure, momentum, species ....) does not change the divergence phenomenon. the residuals go up in the same pattern - for the continuity the residuals follow the same values each time the iterations begin.
can anybody please point out what is going wrong. thanks a ton.
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 05:49
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
parallel processing and dynamic mesh Anand FLUENT 0 January 9, 2009 15:52
Problems with MFIX code and Parallel Processing. Fernando Pio Main CFD Forum 4 August 29, 2006 14:33
parallel processing in numeca sheeev koomaar Fidelity CFD 1 August 18, 2006 02:35
