coal combustion
Old   July 9, 2002, 20:19
Default coal combustion
Changdong Sheng
I am using FLUENT to simulate coal combustion in a pilot furnace, where swirl flow occurs. As simulating, I never got a convergence as coal combustion included. Is there somebody having experience to solve such a problem?
Old   July 10, 2002, 00:15
Default Re: coal combustion
Jin-Wook LEE
I have never met theoretically perfect convergence for the coal combustion with DPM. Gas phase convergence can be obtained fairly easily, but the residuals always increases to the fairly higher values than the convergence criterion just after DPM injection.
So, my personal convergence criterion is,
1) Enough DPM injection, say N(fairly large number) times injection and coupling with gas phase. 2) Gas phase convergence. 3) perfect mass&energy balance including mass and energy transfer between two phases. 4) Nearly same results between N_th converged result and N+1_the converged result for every variables
Oil droplet combustion is fairly easily converged. So, I think that the major source of difficult convergence for coal combustion is large momentum transfer between two phases rather than energy transfer. So, I think that the problem can be overcomed by using very large cell number and very large injection number. I actually have tested couple of times by incresaing and decreasing injection number. For large injection number, the situation was much better.
Sincerely, Jinwook
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 09:39
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 23, 2010 23:56
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 08:05
moisture in coal combustion Sheng FLUENT 3 June 15, 2003 19:43
Coal combustion with Fluent 4.5 or 5.0! Sriram Popuri Main CFD Forum 2 July 24, 1999 11:34
