July 3, 2002, 08:51 |
reation modeling in fluent
I am doing a test simulation(just involve one phase, batch reator, assume perfect mixing at t=0) in fluent, which involves substrate(glucose) consumption and cell prodution. The rate of consumption and production is as described at http://www.dartmouth.edu/~xjshao/sample.htm. There are also some simplification assumptions. I looked into Fluent, but I don't know how to conduct the simulation. I have thought that it could be modeled using the species transport: finite rate and/or eddy dissipation model, but it seems not practical since the stoichiometric chemical reaction equation is not available. Anyone can give me some suggestions. Thanks!
July 4, 2002, 00:11 |
Re: reation modeling in fluent
Stoichiometric reaction is available if A is infinity and E is zero in the Arrhenius rate parameters. You will still have to contact species A with B, say. You can do this by inlet BCs, mass source terms, or patching an initial condition (transient/unsteady calc only).
That aside, you've already defined a rate for your system. Consider modifying the example reaction rate UDF to suite your case and proceed from there. |
chemical reaction modeling using FLUENT | wlt_1985 | FLUENT | 6 | April 16, 2014 07:45 |
Multiphase flow modeling: CFX or FLUENT? | Paul | Main CFD Forum | 8 | January 24, 2012 09:25 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Spray Modeling in Fluent | Truckson8347 | FLUENT | 0 | June 8, 2009 11:25 |
modeling of free boundary in Fluent Software | Mahmoud Alidadi | Main CFD Forum | 1 | August 12, 2005 09:12 |
