July 3, 2002, 06:55 |
Turbulence Model Study
Dear Fluent Users,
I am studying the flow in the simplified 2d radiator with 10 tubes. Before doing this I am doing a model study to see which turbulence model is suitable for this problem. Can anyone suggest a model which is suitable for this problem, and if not the steps to be followed during the model study, I mean how can we decide which model is suitable. Thanks Sridhar. |
July 4, 2002, 00:12 |
Re: Turbulence Model Study
Are you interested in the tube-side or shell/external-side of the radiator?
July 4, 2002, 03:17 |
Hi Lanre,
I am intrested in flow inside the radiator tubes. I made a simple radiator with inlet, inlet connected to inlet tank which is connected to 10 tubes(each 5mm width)and then to a outlet tank and to outlet. I am studying the effect of inlet and outlet position on the fluid flow across the tubes and overall pressure drop between inlet and outlet. Thanks. Sridhar. |
July 4, 2002, 11:23 |
First determine whether the flow is indeed turbulent in the entry and discharge headers, and in the tubes. If the flow is turbulent, I would suggest the RNG k-e model with non-equilibrium wall functions for your developing boundary layer in the tubes.
July 4, 2002, 16:58 |
Thanks Lanre.
Sridhar. |
July 5, 2002, 12:37 |
hi, sridhar mad for deepa
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 22:43 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
Turbulence model for CFX moving mesh | songxguan | CFX | 7 | June 28, 2009 21:05 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 16:15 |
