Writing udf for Transient Heat conduction boundary value problem
Old   October 5, 2015, 13:47
Post Writing udf for Transient Heat conduction boundary value problem
up
abhi12019 is on a distinguished road
I am solving a transient heat conduction boundary value problem and I am stuck at defining the udf for these boundary conditions.
Refer to page number 89 of the following paper for the boundary conditions.
http://eprints.nmlindia.org/5588/1/81-98.PDF
Is it possible to define a udf for this? If yes, how?
abhi12019 is offline   Reply With Quote
Old   October 6, 2015, 11:20
Bruno
brunoc is on a distinguished road
Just a tip: you're more likely to get an answer if you explain what it is you want to do and what have you done so far, rather then expect others to study your problem.
Cheers.
brunoc is offline   Reply With Quote
Old   October 7, 2015, 05:07
Default Regarding problem in boundary condition
up
I am solving a heat conduction problem in whcich a spherical shell is formed on a solid sphere.
Model equation :
From 0<r<R0 and 0<t<ttotal
(1/r^2)*d(Kb*r^2dT/dr)/dr=rho*Cb*dT/dt
From R0<r<R and 0<t<tb
(1/r^2)*d(Kf*r^2dT/dr)/dr=rho*Cf*dT/dt
Initial conditions :
(i)t=0 and 0<r<R0
T=T0
(ii)t=0 and R0<r<R
T=Tbath
Boundary conditions :
(i) r=0 and 0<t<ttotal
dT/dr=0
(ii)r=R0 and 0<t<tb
Kb*dT/dr|b=Kf*dT/dr|f
(iii) r=R and 0<t<tb
T=Tmpbath
(iv) 0<t<tb
Kf*dT/dr|f=rhof*deltaH*dr/dt+h*(Tbath-Tmpshell)
tb<t<ttotal
Kb*dT/dr|b=rhof*deltaH*dr/dt+h*(Tbath-Tmpshell)
Where :
r=variable radius in sphere and shell
R0=Radius of sphere
R=Radius of spherical Shell
t=time
tb=time for base solid dissolve
ttotal=time when entire shell ans sphere dissolve
rho=density
deltaH=latent heat
Kb=thermal conductivity of base sphere
Kf=thermal conductivity of spherical shell
T=temperature
T0=room temperature
Tbath=1250 degree celsius
Tmpbath=1540 degree celsius
Tmpshell=melting point of shell
How to write boundary condition (ii) and (iv) in comsol expressions function.
Old   October 7, 2015, 09:10
Bruno
If you're ignoring fluid flow, what you have is a pretty straight heat conduction problem with phase change. You can solve that in Fluent without the need of UDFs by using the 3D solver with the solidification model.
The BC you mentioned will be handled automatically by Fluent in this case.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Define_profile UDF for Transient Heat flux boundary condition Amoljoshi Fluent UDF and Scheme Programming 2 June 20, 2018 21:55
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 11:14
Heat conduction problem help lucky_m_m Main CFD Forum 0 October 17, 2013 08:15
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
