UDF for Electrostatic Field
Old   August 7, 2002, 15:18
Default UDF for Electrostatic Field
Zhenan Li
Could you check this UDF for me please?
The electrostatic field defined using UDS. I want to add the electrostatic force acting on a charged particles in the field. The following is a simple code.
Thanks,
#include "udf.h"
#define PI 3.14159265
#define EPS 8.854e-12
DEFINE_DPM_BODY_FORCE(particle_body_force, p, i)
Thread *t;
real x[ND_ND];
real y;
real bforce;
real Q = 2.0e-6; /* Particle electric charge */
cell_t c;
C_CENTROID(x, c, t);
y = 0.3 - x[1];
bforce = C_UDSI_G(c,t,0)[i]*1000.0*Q + Q*Q/(16.0*PI*EPS*y*y)*(C_UDSI_G(c,t,0)[i]/NV_MAG(C_UDSI_G(c,t,0)));
return (bforce/P_MASS(p));
Old   August 11, 2002, 21:58
Default Re: UDF for Electrostatic Field
Alamgir
Zhenan,
Could you plz help me, which particles u using, where did get information about Q, which equation u r using?
look, u wrote bforce= ..............., at the end of the equation there are 3 ))), I think this could be a problem. look according to your equation whether is it correct of not?
Alamgir
Drag coefficient, DPM. jorge poyatos FLUENT 14 January 20, 2012 13:41
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
Porosity field in Fluent wojciech FLUENT 1 September 20, 2010 11:19
Help Parallelizing UDF AndresC FLUENT 0 February 25, 2010 15:50
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
