temperature limitation?
Old   August 7, 2002, 04:22
Default temperature limitation?
Deadly
Im trying to run my full model, using symmetry..I initially ran my full model wihout having symmetry, emaning i drew out the whole geometry..and solved.. But when i draw the half model and start iterating, using symmetry, i find that i get message syaing a temperature limitation in a partucular zone with 6000 cells.. I do not get this when i run the full model, so by right i should not be getting that message with the symmetrical model right? Can someone shed some light on this? Thnk you
Deadly
Old   August 7, 2002, 04:37
Default Re: temperature limitation?
Laika
Do you have this warning just during the first few iterations, or throughout the entire simulation?
Laika, still orbiting
Old   August 7, 2002, 07:35
ahmet
How is done combustion modelling in gas turbine combustor?
Newer, I can also predict pollutant formation, especially, NOx and CO emissions.
Old   August 7, 2002, 09:48
Puck
The first 4 iterations went fine..but after tht i had reversed flow for another 4 more iterations..From around the 10th iterations onwards i started having the temperature limitation thingy.. also, when i saw tht happening until my 18th iteration, i stopped iteratins, went to the limits panel and increased the temp limit to 50000..i know i shouldnt anyhow increase it, but i just wanted tio see how high the temperature hits...
Old   August 7, 2002, 10:00
Deadly
The first 4 iterations went fine..but after tht i had reversed flow for another 4 more iterations..From around the 10th iterations onwards i started having the temperature limitation thingy.. also, when i saw tht happening until my 18th iteration, i stopped iteratins, went to the limits panel and increased the temp limit to 50000..i know i shouldnt anyhow increase it, but i just wanted tio see how high the temperature hits... Somthing seems wrong..
P.S ..im using a different nick in sch and home..hope i didnt cause a nuisance by posting two same messages under different nick.. Apologies:P
Old   August 7, 2002, 10:50
Laika
-mostly the problem is not the temperature, but the velocity-field. Check your boundary settings
-never change the temperature limit, unless you are sure in reality you have temperatures of that magnitude.
Old   August 7, 2002, 22:29
Deadly
But the weird thing is..i dun get this problem when i run the full model.. Only when i run the symmetry(half model), i get this problem..My velocity setting are the same as that for the full model.
Kalai
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
k residual goes up after temperature limitation warning??? Catthan FLUENT 0 November 24, 2010 17:48
Temperature limitation Karthick FLUENT 2 May 10, 2004 08:12
how to overcome the temperature limitation fanadam FLUENT 3 June 17, 2002 04:39
