use of cavitation model
Old   July 30, 2002, 10:52
Default use of cavitation model
gdv
hi everyone,
I used cavitation model in my case but pressure values in some zones remain absurdly under the vaporization pressure value (negative values too). I tried to use different n values and different time steps but nothing seems to change. How can I avoid this?
Thank you
Old   July 31, 2002, 02:58
Default Re: use of cavitation model
Lanre
Check the Courant number for your problem. You may require an absurdely low time step, e.g., ~1e-6s or less. Try bracketing your pressure by setting max and min pressure limits for your simulation. Use low underrelaxation for pressure, e.g., 1e-3. The bubble density should affect your results so specify a realistic value.
Old   July 31, 2002, 04:53
hvn
By negative values of pressure, do you speak about absolute or relative pressure?
Regards,
HV
Old   July 31, 2002, 05:10
gdv
Thank you for your responce,
I mean, unfortunately, negative absolute pressure.
Regards,
gdv
Old   July 31, 2002, 05:18
gdv
Thanks for your responce, I can try to reduce time steps during the unsteady solution but i can't reduce CFL number because i'm using segregated solver and, ,moreover, unfortunately, i can't limit pressure values because my flow in incompressible. I will tell you the new results.
Regards
gdv
Old   August 1, 2002, 02:55
Lanre
I meant for you to use the Solve->Controls->Limits... to set min and max absolute pressures to control your solution. Once you have the solution progressing you can relax the min and max limits to be more realistic.
Old   August 6, 2002, 04:57
Mark Render
reading your discussion the question came to my mind:
Is it really so strange or even impossible that the absolute pressure becomes negative ?
If there is a small nuclei content in the water perhaps the water won't vaporize at the saturation pressure but only at lower pressures.
Any opinions on that ?
Regards,
Mark
Old   August 7, 2002, 12:48
gdv
Thank you Mark,
I think that your observation is correct if we want to see qualitatively where cavitation occurs but absolute negative pressures affect the velocity field overestimating local velocity values (in the case one imposes a pressure drop on an incompressible flow) and so possible choking effects on flow rate through an orifice cannot be observed.
Regards
cavitation model pressure distribution Rahmat Arazgaldy FLUENT 1 May 16, 2012 16:48
Cavitation model with non-isothermal flow pitisrisuk CFX 0 July 14, 2009 15:30
Cavitation Model Umesh Shah FLUENT 0 June 26, 2006 18:09
About Cavitation Model and General setting wayland Siemens 0 January 15, 2006 22:30
Mixture Model (cavitation) Victor FLUENT 3 April 5, 2005 05:38
