Integration with personal code!
Old   August 4, 2002, 17:51
Default Integration with personal code!
Deepak
I was wondering if I can call Gambit/Fluent functions from my C or Fortran program or from shell script... I know about running Fluent in batch mode, but this would be different as I'd like to give commands from my C program. Thanks.... - Deepak...
Old   August 11, 2002, 21:37
Default Re: Integration with personal code!
Greg Perkins
I don't think you can do this - but you can do the reverse - ie. you can link your code into the Fluent code. You could then run your code (get Fluent to run it) and access some internal functions. However, depending on what you want to do, I'm not sure it would be a good idea.......
Greg
Old   August 12, 2002, 10:53
Deepak
Hi Greg, Thanks... I guess I'll have to do with running in batch mode. Anyway just to elaborate I wanted to use a function like mainan(" ") for Ansys where I can give Ansys commands from my C program. Anyway I guess this can't be done in Fluent.
Thanks, ----Deepak...
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 12:30
Debugging Unsteady 2-D Panel Method Code: Wake Modeling RajeshAero Main CFD Forum 5 November 10, 2011 05:48
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 11:02
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 10:11
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
