August 21, 2002, 11:39 |
Please help!! Patch and Species transport
Dear All,
Sorry for posting so many questions in the forum...But I'm gettin towards the deadlines and Im reallie worried. I am modelling the spread of a source of gas in a ventilated room (air). When I want to patch a zone for species transport modelling, in the patch panel i click on the species and there is a box for me to enter a value, but it did not have any units or description of what value it is refering to. Is this value mass fraction? So if my zone is purely of one species, I just enter a value of 1 into the selected species? Also, if it is mass fraction, and i input the value of 1 in the small volume of zone, how much of the species (in terms of mass e.g. kg or grams) am I actually inputting? Or the only way to measure is by ppm, where ppm= mass fraction of the species x 1000000?? Also, this question is asked in my other thread in the forum, but just in case different pple read this thread, they may have a clue of how to do it: If I create a new mixture using the species already defined in the database, are the properties of the overall mixture formed automatically calculated and updated by Fluent? Or do we still have to find out the values thru books and input them in ourselves? |
August 21, 2002, 20:11 |
Re: Please help!! Patch and Species transport
Yes, that value is mass fraction.
I recommend that you use 'MASS SOURCE' in boundary condition panle. You can use Fluent's various option in the MATERIAL panle. Fluent's default setting is based on the constant value for the properties at the room temperature. Sincerely, Jinwook |
August 24, 2002, 11:18 |
Do you mean from the BC of my fluid zone, I could specify "mass source"? But under fluid zone BC, when I turn on the source terms, it is in kg/m^3sec but my source is not constantly emitting mass of ammonia gas in every second.
so I decided to use patch where I will telling fluent that there is a fixed intial amount of source at a certain position. Also, I have another question which I have posted out recently, wonder if you could help. I need my concentration of ammonia gas in the room to be about 40mg/m^3, and from the volume of my room, I calculated that there should be 0.006272kg of ammonia gas in the room. Hence using the density of ammonia gas, I calculated the volume occupied by this amount of ammonia gas, thus able to patch this volume. However the conc of ammonia gas is really very small 40mg/m^3 of the room, hence it is 0.00004Kg/m^3 but the plot of conc with time is only up to 4 decimal places, do you by any chance know how to increase the number of decimal places such that my y-axis values will not be all 0.0000. Thanks. |
September 24, 2012, 15:24 |
#4 | |
Snh
I am facing a similar problem of entering the specific quantity of reactant using the patch option in my simulation. I would like to know how you tackled with the problem. It would be of great help in my project. |
September 25, 2012, 10:55 |
#5 | |
shoeb khan
You can check the volume average in the domain of that species there. Hope that helps Shk |
August 3, 2016, 03:10 |
Having the same issue!
leekeanwee
Rep Power: 9 |
Guys, urgently in need of help here! What value should i put if i want to have 100% of the species variable i chosen (eg: water) in the region i marked?
I tried the value 1 (assuming the value means mass fraction) but only 50% of the region i marked is filled with water. the other 50% is filled up by air! Sorry to bump an old thread but i have been finding a solution for weeks now. any help is extremely appreciated! |
Combustion Chamber Species Transport | Catthan | FLUENT | 2 | April 27, 2021 03:39 |
PB: Saving mass fraction of species on two points with an udf | biget.a | FLUENT | 2 | July 23, 2009 03:06 |
patch two species in one region | Laure | FLUENT | 1 | May 25, 2007 13:08 |
problems on species transport | shao1 | FLUENT | 0 | July 11, 2002 21:58 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
