unnecessary wall(bc)-help needed
Old   August 30, 2002, 11:27
Default unnecessary wall(bc)-help needed
Shankar
In my geometry there are 2 volumes like a pipe (1 volume) opening in to a container(2nd volume).After meshing, in the first volume the tip of the pipe by default(when the mesh is exported to fluent) is set as wall(boundary condition), but clearly that shouldnt be a wall.Any suggestions?Thanks. Shankar.
Old   August 31, 2002, 14:13
Default Re: unnecessary wall(bc)-help needed
Taher
Sure you must specify that boundary as interior manually .
Old   September 1, 2002, 04:34
david
If you don't specify the interface between two fluid volumes, by default gambit used to consider this as an interior. Funny thing is this feature doesn't work in the latest version of Gambit sometimes.
DC
Old   September 2, 2002, 18:29
Shankar
Thanks to both of you.I tried to specify it as "interior" manually, but when exported Fluent says that particular face cannot be specified as "interior".
Old   September 3, 2002, 02:48
david
ha ha this is the latest beauty of gambit !! Try try again and again !! DC
Old   September 3, 2002, 12:27
varghese
Dear Shankar,
I would suggest you to carefully check the connectivity of the two volumes. When they are not really connected, an unnecessary face is formed, in between.This usually occurs when you split the geometries.
Greetings,
Varghese
a CFD software is needed... maxgzc Main CFD Forum 3 September 27, 2011 01:51
no rules for target *Foam.dep which needed... goodkid OpenFOAM Programming & Development 2 May 12, 2011 20:54
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 15:20
a dissertation in ETD needed very much LiQiang Main CFD Forum 0 March 11, 2005 03:09
CFD Software Engineer needed in Fort Worth, Texas Ross Main CFD Forum 0 November 19, 2001 14:48
