August 29, 2002, 08:25 |
Fluid flow
I am currently doing my final year project on the "Analysis of Pressure Transients Caused by The Entry of A Train Into A Tunnel".
Is there any websites, books, journals or tutorial that i can refer to that is relevant on how to model a train entering a tunnel portal in 3D space?? Please advice... |
August 29, 2002, 22:25 |
Re: Fluid flow
Do you have access to massive parallel computing facilities ?
DC |
August 30, 2002, 01:24 |
Re: Fluid flow
sorry, i do not really know what is "massive parallel computing facilities" but i think i will be able to access most of the computers in the school. By the way i am using Gambit 1.1 and Fluent 5/6 for my work.
August 30, 2002, 21:59 |
Re: Fluid flow
How details you wannna model of the structure of the train ? Are the humen travelling in the train ? Will they be breating ? What about heat loss from their bodies? Are they of same size ? What kind of engine are you considering to consider the heat generation? The tunnel itself is of regular shape ? ser chong you are in trouble !!! DC
August 31, 2002, 19:54 |
Re: Fluid flow
Basically, i would like to investigate the pressure pulses generated and propagating in the tunnel during the entering at the tunnel portal.
Modeling a simple model will do, i am also assuming no wheels, condensing units and others under or on top of the train. It would just look like a long rectangular block entering a rectangular hole. Later, i would also like to know what type of portal entry shape will reduce the pressure waves. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
MR Fluid Flow through microchannels | Sinan | FLUENT | 0 | September 18, 2004 00:03 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
