Unsteady Simulations of Phase Change
Old   September 26, 2002, 05:30
Default Unsteady Simulations of Phase Change
Mike
I am currently doing simulations of a 2D, rectangular enclosure containing wax( with melting point = 317K). My boundary conditions are that the vertical copper wall surfaces are at a isothermal temp. of 363K and the horizontal wall surfaces are adiabatic at 300K.
My model used in Fluent 6.0 is unsteady, segregated, and first order implicit.
As this is a conduction problem, the heated walls will conduct the heat into the wax, causing the wax to melt.I need to monitor the liquid fraction as it varies with time.
Is there anything else i have to include or have excluded?
Thanks!
Unsteady flow phase shift fuat FLUENT 0 October 31, 2008 03:20
water 2 phase, Change from hight to low temp panuwat FLUENT 0 June 19, 2006 08:50
Solid Phase change material qiulan Siemens 0 June 5, 2006 15:30
phase change rookie FLUENT 3 June 12, 2003 20:47
Phase change process Sang-jin Lee Siemens 5 December 5, 2001 05:17
