September 5, 2002, 10:28 |
help: which VOF model
hi there
i am doing stirred tank simulations and need to take the liquid surface into account. i don't require sophisticated surface tracking, just something which is robust and will work on a (coarse) grid with sliding mesh. any experience or recommendations would be very welcome. thanx |
September 5, 2002, 10:49 |
Re: help: which VOF model
this should be no problem. My experience is that sliding mesh + vof takes very very very long to converge to a physical meaningful solution. Solution: run a moving reference frame model in steady state, and, if necessary, switch tot sliding mesh after convergence.
good luck, Laika, back in orbit |
September 6, 2002, 05:41 |
hi,
In my experience, VOF isn't very robust and won't works on a too coarse grid (results may be completly unphysical). If you need to take into account that there is a free surface but it's deformation is small enought to don't interfere with flow field near the agitator you can use a free slip wall. Best regards |
Display Modes | |
VOF Model or Mixture Model | mems21 | FLUENT | 2 | March 9, 2010 10:37 |
A Problem with setting the time step in VOF model | Le | FLUENT | 2 | July 20, 2006 22:00 |
free surface of VOF and melting model? | wanghong | FLUENT | 3 | March 13, 2006 09:57 |
help needed for vof model | yan | FLUENT | 3 | December 16, 2005 01:17 |
Moving mesh or VOF? | Giovanni | Main CFD Forum | 16 | September 24, 2001 08:25 |
