What kind of BC should be surround a heat source?
Old   September 19, 2002, 05:16
Default What kind of BC should be surround a heat source?
Marie
Hello Fluent users,
In the air, there is an energy source. The heat released will induce the air flow(natural convection). For such a case, what kind of boundary conditions should be used? ( Inflow or Outflow?)
Thanks.
Marie
Old   September 19, 2002, 06:38
Default Re: What kind of BC should be surround a heat sour
Ashu
In the domain away from the source you can use pressure out or pressure in boundary condition (on the faces) at ambient. This will allow air to enter or exit air depending on pressure.
Hope this meets your request!
Ashu
Moving heat Source AB FLUENT 2 January 30, 2012 07:06
Heat source function of mass flow MarcVi Fluent UDF and Scheme Programming 0 September 16, 2010 13:16
Heat source in a particular region inside the fluid domain robingilbert OpenFOAM 7 September 2, 2010 14:39
moving heat source Mehdi FLUENT 0 March 24, 2008 17:32
heat source problem John FLUENT 1 April 9, 2003 13:08
