Problem starting Fluent
Old   October 25, 2002, 08:41
Default Problem starting Fluent
Ankan Kumar
I am trying to install and run Fluent. But at the outset there is a message coming up "Flexlm Error---System clock has been set back" and then Fluent fails to load. Whats the problem..? The date on my PC is not changed. What is the way out..?PLease help! Thanks
Old   October 25, 2002, 09:13
Default Re: Problem starting Fluent
Erwin
I just saw the same problem on an NT machine...
I don't know yet what is causing it, but I know how you can circumvent it. Assuming you are running NT, do not start Fluent from the Programs menu but open up a DOS Command window. Change to a drive where Fluent is not located (or not part of the PATH, dunno yet) and then start it up by the command 'Fluent 3d'.
Old   October 28, 2002, 04:44
Gavin Buckton
This is a security measure to prevent people setting the date back on thier machines to prolong the usage of the license.
Check that the time and date are correct on the machine and then do a search for files by date, the start date being the current date and leave the other date blank. This will search the machine for all files with a future date on them. Delete or move these files off the system and restart the machine. Hope this helps.
Old   October 28, 2002, 05:33
Ankan Kumar
thanks for your responses..dunno what was the problem..Just reinstalled windows and everything is working fine.
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
Problem running a parallel fluent job on local machine via mpd highhopes FLUENT 0 March 3, 2011 05:07
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 13:31
Can Fluent 6.0.20 predict this problem right? Yazid Bindar FLUENT 0 March 5, 2003 08:07
Can FLUENT solve this type of problem? Whitaker FLUENT 3 October 23, 2000 03:01
