Turbulence Intensity at an opening
Old   October 12, 2002, 20:05
Default Turbulence Intensity at an opening
lei
Hi, all
In the manual of Airpak2.0 Chapter6.(P.6-24), it is said that the turbulence intensity of 1% is low, while 10% is high. But if I set the turbulence intensity greater than 10%, for example, 15% or 30%, does it have any meanings? Does Airpak use these number to calculate? If not, what is the limit of turbulence intensity in calculation?
Thanks in advance.
Lei Waseda university.
Old   October 14, 2002, 06:41
Default Re: Turbulence Intensity at an opening
Erwin
Of course it has a meaning. The program uses these values to calculate the level of turbulence that is transported into your domain.
Be sure to relate your turbulence intensity to the specified inlet velocity.
Old   October 14, 2002, 23:22
lei
Hi, Erwin
Thanks very much for your reply. Could you tell any practical examples which have the turbulence intensity over 30% at an opening?
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
