Please, how to setup different initial condition. |
November 7, 2002, 06:48 |
If have a closed 2-D tube with a film in it, and want to set different pressure between the film(such like at one side is 1 bar another side is 5 bar). How to do this please?
November 8, 2002, 08:51 |
Re: Please, how to setup different initial conditi
You use the function Solve-initialize-patch.
First, initialise the whole domain with - say - 1 bar. Then, mark the region where you need 5 bars (using Adapt - region). You now have a register containing the limited cells. Use the patch dialog to patch the new pressure into the wanted marked region using the created register. |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
ForcesCoeffs | ronaldo | OpenFOAM | 4 | September 14, 2009 07:11 |
Negative value of k causing simulation to stop | velan | OpenFOAM Running, Solving & CFD | 1 | October 17, 2008 05:36 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
