November 1, 2002, 07:39 |
turbulence boundary values in the atmosphere
Hi folks,
I´m trying to model an air intake system which will be flown on an aircraft for atmospheric research purposes. In principle, it is a simple tube facing the free air stream. For this modelling, I use a k-epsilon turbulence model. I wonder if anybody can tell me, which values for the "turbulence intensity" and the "turbulence length scale" are appropriate at the inflow boundary conditions far away from the intake? In other words, what are resonable boundary conditions for a k-epsilon model (or turbulence in general) for the free atmosphere at 5-12 km altitude? Best regards, Markus |
November 6, 2002, 03:39 |
Re: turbulence boundary values in the atmosphere
For Turbulence Intesnity a resonable value for atmospheric condition is around 10% and Turbulence length scale you can take it around 70-80% of tube diameter. Hope you get some idea Best of Luck Sohail
November 6, 2002, 05:13 |
Dear Sohail,
thanks for the information. I will use your recommendation. Best regards, Markus |
2D airfoil simulation, turbulence, boundary layer, unstructured grid | louis.langouche@gmail.com | FLUENT | 0 | March 3, 2010 08:19 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Recommended values on turbulence B.C. | Jihwan | Siemens | 2 | August 10, 2005 07:45 |
values for turbulence models | Ben | Siemens | 8 | July 12, 2004 13:42 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
