temperature limited
when I use the constant wall temperuature as the boundary condition of wall, the flow is periodic flow,Fluent will display "temperature limited to 1.000000e+00 in 103500 cells on zone 2 Done",what should I do?
Re: temperature limited
If you are using segregated solve reduce engery relaxation factor. It may solve your problem.
Rahul |
3x
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
Hi, try reducing the under-relaxation factor for energy and also switch energy to a higher order scheme. It should work.
