an easy question about gambit
Old   November 29, 2002, 22:52
Default an easy question about gambit
brian
When i export the mesh file from gambit,how can i chang the saved directory ? thank you very much!
Old   November 30, 2002, 01:06
Default Re: an easy question about gambit
MissNancy
do the following: save as, then you will fins the current directory where you saved before or from where you ran gambit. Find the directory ending with double dot (..), most probably the second in the list from the top. Double click that, u will go down one directory.. so if u want to go down, again double click the one with .., to go up a directory, double click the directory.
Alternatively, type the directory location, then slash, then file name.
U can also cut and paste the directory name from the Unix terminal.
Hope this is what you are looking for.
Nancy
Old   December 2, 2002, 03:33
varshavian
it's easy. you can select your favorite directory by browser.
Old   December 2, 2002, 23:58
Alamgir
Save anywhere then use vi command: cp <file> .. \dir or use transfer file window and copy/paste just like windows explorer or drag the file and release it to your destination folder.
Alamgir
Easy GAMBIT question noName FLUENT 1 March 31, 2005 02:09
Gambit question HP FLUENT 8 March 4, 2005 08:32
Question on Gambit. Sham FLUENT 2 February 15, 2005 20:07
Easy question Confused Main CFD Forum 4 May 22, 2004 02:14
GAMBIT Question Eric FLUENT 2 February 28, 2002 22:24
