turbulent viscosity causes solution divergence |
December 23, 2002, 11:36 |
Running a simulation where a square duct intersects a circular volume, there are narrow triangular sections which it seems impossible to eliminate elongated cells from.
The turbulent viscosity becomes very high in this region and causes the solution to diverge, particularly continuity. What is a good solution to this grid/solution problem? Adding more elements I understand may risk negative volume connectivity issues. Any other suggestions? Thanks, Steve |
"turbulent viscosity limited to viscosity ratio" | olivier | FLUENT | 11 | October 10, 2015 05:49 |
Turbulent viscosity | eng.nassim | FLUENT | 4 | August 19, 2009 11:41 |
Turbulent viscosity limited to viscosity... | Cyril | FLUENT | 16 | October 4, 2007 06:12 |
turbulent viscosity ratio | James Willie | FLUENT | 1 | June 21, 2005 03:35 |
