Grid error
Old   January 15, 2003, 13:56
Default Grid error
Chris
When there is a grid error owing to negative volume, how should I go about correcting that error? Thanks
Old   January 15, 2003, 21:11
Default Re: Grid error
jieremy
I think it is for the sharp angle in your volume if you mesh stucted gid .but you can void it by meshing unstructed gird .If you mesh unstructed grid and meet the same error again ,then you can change the mesh size smaller .just do it !
Old   January 16, 2003, 05:23
Chris
Thanks, I will attempt to do that!
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
user defined function cfduser CFX 0 April 29, 2006 10:58
