Error message when setting BC
Old   January 27, 2003, 09:24
Default Error message when setting BC
Mnu & Luc
Hello, me and my famous workmate have an interesting error message when opening a continuum BC (solid zone):
Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: #f
Old   January 28, 2003, 14:07
Default Re: Error message when setting BC
Ray
I would like to know as well. I get the same error message but only when I activate the energy equation and try to open the solid zone BC.
Old   January 28, 2003, 14:33
Erwin
It means that a field in your window has not been set (it has the value #f = empty). I saw it, e.g. in a porous zone where the solid material was not set after I read a case file from one old version of Fluent into a new one. In stead of Aluminum or so the field is empty.
So, check all your fields very carefully to see if they make sense.
Old   January 28, 2003, 15:18
Ray
I'm trying to specify a fixed temperature in a solid and it won't let me. I don't know what fields I should be looking at to determine why the message is occuring.
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Sover setting with TUI junbbung FLUENT 0 August 20, 2009 00:43
LiftDrag utility from v12 to v141 cfdphil OpenFOAM Running, Solving & CFD 2 December 5, 2007 05:49
Ultra high temperature? bk Siemens 2 July 19, 2005 00:01
Warning 097- AB Siemens 6 November 15, 2004 04:41
