February 5, 2003, 09:55 |
Coupled interpolation possible??
Hi, I must realize studies about a waterblock to cool processors but I need to try about 7 differents thickness for the copper baseplate (power spreading in the block) in order to find the best thickness which give us the better cooling (lowest temperature for die processor).
But I DON'T want to calculate 7 time the flow inside the block because it is always the same. Only thickness of baseplate (under the flow) change and temperature prediction are given in 2 minutes with fluent. Look at the problem on a 3D block here : http://membres.lycos.fr/roscool/forum/block.gif So is there a way to keep the flow data inside my water volume and change the solid volume around it? Is interpolation is possible keeping the flow? Or I should calculate all 7 time ? Other solutions? Thx for answers |
February 5, 2003, 11:32 |
Re: Coupled interpolation possible??
It's good, I have found the interpolation function.. It works great ^^
urgent help needed (rhie-chow interpolation problem) | Ardalan | Main CFD Forum | 2 | March 18, 2011 15:22 |
Surface interpolation schemes and parallelization | jutta | OpenFOAM Running, Solving & CFD | 0 | February 25, 2010 14:32 |
Some confusion about coupled solver for incompressible flow | bearcat | Main CFD Forum | 0 | February 14, 2010 20:40 |
momentum interpolation for collocated grid | Hadian | Main CFD Forum | 4 | December 25, 2009 07:25 |
Coupled 1D/3D STAR-CD Training | CD adapco Group Marketing | Siemens | 1 | November 13, 2002 15:48 |
