Flow + split volume
Old   February 13, 2003, 13:38
Default Flow + split volume
Mark
I am trying to solve an air flow within a pipe that has restrictions such as orifices. To create a mesh I decomposed the volume using split tool.
My problem is that I can't get the flow to flow through the entire volume. The flow won't go passed the split in the volume.
I have checked that the faces are connected and they seem to be connected. I did this by geometry/face/connect - select all/apply. I then get the warning - operation resulted in no actual connection.
Is this the right way of doing the face connection check?
If this is the right way to check the faces are connected, can anybody suggest another reason as to why the flow stops at the split in the volume?
Regards,
Mark
Old   February 16, 2003, 10:23
Default Re: Flow + split volume
Erwin
First connect all the vertices, then connect all the edges. Now your volume will be connected properly.
Old   February 17, 2003, 04:10
sev
Mark,
I had a simular problem once and it was because I made a mistake in the selection on the faces for my wall boundaries. Also dont forget to select all your volumes as 1 fluid. hope this help
Old   March 18, 2003, 10:09
Paul
Try to define splitting faces as INTERFACE boundaries in Gambit. Then define Grid Inerface in FLUENT. This way U have not do coincident mesh. Luck.
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Gambit split volume option John peter FLUENT 2 May 2, 2011 22:29
why i can't split a real volume with a virtual face. George Chen 28 Main CFD Forum 0 March 8, 2010 03:41
Volume split -- Meshing Kantipudi FLUENT 0 July 27, 2008 12:18
volume fraction, Mass fraction and Bulk Mass flow Dr.jones CFX 1 January 25, 2006 04:32
