A simple question!
Old   February 26, 2003, 04:03
Default A simple question!
Raintung
I don't know how to use "tm3d218.exe"? And when should I use it? Thank you1
Old   February 26, 2003, 12:08
Default Re: A simple question!
Erwin
That looks to me the 3D version of tmerge, a utility you use to merge different meshes into one. You don't access it directly, it is called by a program "utility".
Old   February 26, 2003, 19:49
Raintung
Thank you! But, If I need merge different meshes, What should I do?
Old   February 27, 2003, 10:11
Erwin
Open up a DOS windows and enter at the command prompt:
utility tmerge -3d -p sourcefilename1.msh sourcefilename2.msh targetfilename.msh
The -p means no other commands need to be executed, if you omit it the program will ask for translation and scaling factors etc.
Simple Outlet Question m.nichols19 OpenFOAM 3 June 25, 2010 01:44
Simple Question Regarding Symmetry Planes Atella CFX 3 April 11, 2010 06:44
Simple Question Regarding Symmetry Planes Atella Main CFD Forum 0 April 9, 2010 10:58
Question of Anil Date's SIMPLE method universez Main CFD Forum 0 November 18, 2009 20:12
Simple Question Regarding Continuity Closure RC FLUENT 2 March 25, 2004 05:30
