simulation with ideal gas material properties |
February 28, 2006, 07:03 |
Hi, i am simulating the airflow over a diffusor in the compressor of a turbocharger with fluent 3d.
I select the option density =ideal gas in material properties, and i dont know how to initialize the problem. I have the following boundary conditions:inlet massflow, and the outlet pressure. I already tried to initialize with both, massflow and pressure outlet, with pressureoutlet and introducing my own values. I always get this error: divergence detected in AMG solver If i use the constant density model i dont find any problem. if anyone can help me, i would thank you |
February 28, 2006, 07:04 |
Re: simulation with ideal gas material properties
the error was divergence of temperature. Sorry
February 28, 2006, 07:17 |
Usually when dealing with ideal gas, I initially disable the energy equation in Solve/Controls/Solution. Once the problem tends to converge, I enable the energy again. This procedure is also recommended in the Fluent manual and it works most of the time.
March 1, 2006, 16:27 |
I have had a similar problem and substituted my own polynomials for the gas properties, which eliminated the divergence error. Also, for some reason I don't understand (and have a request in to tech support for), Fluent's model for air seems to give half the conductivity and 1/3 the specific heat that it should.
July 3, 2019, 19:27 |
#5 | |
Ali Gürcan
Rep Power: 6 |
thanks |
July 7, 2019, 00:36 |
try this
#6 | |
Ali Gürcan
Rep Power: 6 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Exhaust Gas manifold simulation | shrinath | Siemens | 6 | September 5, 2013 16:26 |
How to add more material properties | sarahsun | CFX | 1 | October 27, 2009 07:27 |
problems simulation ideal gas, divergence in AMG S | Ralf Schmidt | FLUENT | 11 | October 1, 2005 13:21 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
