How to improve y-velocity
Old   March 27, 2003, 10:56
Default How to improve y-velocity
ravi
Hi everyone, I have simulated a 2d open channel flow with good results but the Y-component of the velocity seems to be different, are there any ways to improve this?? using k-epsilon RNG turbulence model.
I need help very urgently. thanks
Old   March 27, 2003, 13:02
Default Re: How to improve y-velocity
Alex Munoz
Hi Ravi
I don't know why do yo want to compare y-velocity between models? This is not a good criteria to compare models.
I suggest that you compare velocity/max velocity, axial and tangetial Reynolds normal stress and turbulent kinetic models.
I good reference for you to learn how to analysis CFD could be: Martinuzzi R., & Pollard, A. (1989) Comparative Study of Turbulence models in Predicting Turbulent Pipe flow. AIAA Journal vol 27 no1 29-36.
In addition K-e and RNG models generally can not predict accurate y-z-velocities. If you want to optain better result try RSM!
I wonder if you are imposing k and e inlet profiles besides to the x-velocity
regards
Alex Munoz
Old   March 28, 2003, 08:01
ravi
Dear Alex, Firstly where can i find axial and tangetial Reynolds normal stress in Fluent? Can i plot a contour? Is it available in 2d? Secondly Unfortunetly my uni library does not have the AIAA Journal vol 27, they only have vol 28-39, is there anywhere i can get a hold of this journal? online journal would be great but i was unable to locate any on the net. Thanking you in advance for your help
regards
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Velocity Under-relaxation in SIMPLE type methods Matt U. Main CFD Forum 6 July 4, 2005 05:29
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
