March 27, 2003, 11:56 |
How to improve y-velocity
Hi everyone, I have simulated a 2d open channel flow with good results but the Y-component of the velocity seems to be different, are there any ways to improve this?? using k-epsilon RNG turbulence model.
I need help very urgently. thanks |
March 27, 2003, 14:02 |
Re: How to improve y-velocity
Hi Ravi
I don't know why do yo want to compare y-velocity between models? This is not a good criteria to compare models. I suggest that you compare velocity/max velocity, axial and tangetial Reynolds normal stress and turbulent kinetic models. I good reference for you to learn how to analysis CFD could be: Martinuzzi R., & Pollard, A. (1989) Comparative Study of Turbulence models in Predicting Turbulent Pipe flow. AIAA Journal vol 27 no1 29-36. In addition K-e and RNG models generally can not predict accurate y-z-velocities. If you want to optain better result try RSM! I wonder if you are imposing k and e inlet profiles besides to the x-velocity regards Alex Munoz |
March 28, 2003, 09:01 |
Dear Alex, Firstly where can i find axial and tangetial Reynolds normal stress in Fluent? Can i plot a contour? Is it available in 2d? Secondly Unfortunetly my uni library does not have the AIAA Journal vol 27, they only have vol 28-39, is there anywhere i can get a hold of this journal? online journal would be great but i was unable to locate any on the net. Thanking you in advance for your help
regards |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 14:58 |
Steady pipe flow mean velocity higher than inlet velocity | anita | OpenFOAM Running, Solving & CFD | 7 | September 25, 2012 06:35 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 07:10 |
Velocity Under-relaxation in SIMPLE type methods | Matt U. | Main CFD Forum | 6 | July 4, 2005 06:29 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
