problem in transcient heat flux b.c in UDF
Old   April 8, 2003, 09:29
Default problem in transcient heat flux b.c in UDF
phani
i am simualating solidification and melting problems in the fluent6.0,so for that i have to give heat flux boundary condition varing with time. So i have written the Udf for that but it is diverging after time (15sec) it is diverging in the third condition of the udf.So could u plz help me
#include "udf.h"
#define d 0.04 #define C 2.18844 #define D -0.602603 #define A 762.048e04 #define B -0.217412 #define den 8960 #define kc 363 #define cp 423
DEFINE_PROFILE(heat_flux, thread,position) {
real alpha, qmax,q;
face_t f;
alpha=kc/(den*cp);
qmax=A*pow(d/alpha,B);
begin_f_loop(f,thread) { real t=RP_Get_Real("flow-time");
if(t<=5)
F_PROFILE(f,thread,position) = qmax;
else if((t>5)&&(t<=15))
F_PROFILE(f,thread,position) = qmax-6.5715e4*(t-5);
else
F_PROFILE(f,thread,position) =- 2.0152e6*C*pow(t,-D)/(pow(alpha,0.05));
} end_f_loop(f,thread) }
Old   April 8, 2003, 10:43
Default Re: problem in transcient heat flux b.c in UDF
Alex Munoz
hello
Couple of mistakes
All the number must to have the form 5. or 5.0 not the form 5 in order to assign the decimal number.
also you don't need to write this sentences like this else if((t>5)&&(t<=15)) you can write the sentes like this else if(t<=15.0) F_PROFILE(f,thread,position) = qmax-6.5715e4*(t-5.0);
Best Regards
Alex Munoz
Old   April 9, 2003, 00:13
phani
Hai Alex,
thank's for responding,i did what u said, again the solution is diverging at the third condition i.e [F_PROFILE(f,thread,position) =- 2.0152e6*C*pow(t,-D)/(pow(alpha,0.05));] when the fluent is solving the above equation, and the solution is get diverging.
Old   April 9, 2003, 00:58
Alex Munoz
Hi
It is correct that you define D=-### and then in your function you writhe pow(t,-D)?
I wonder if you are making -*-=+
In addition how do you know that fluent is diverging in the third condition, the code is not able to tell you that type of information.
Just it has divergence but how you can ensure that it is due to the UDF??
Regards
Alex
UDF for wall heat flux ? Seyoung Oh FLUENT 6 August 4, 2018 05:44
heat flux balance problem zhouziyi7123 FLUENT 5 May 21, 2014 03:37
Variable name for heat flux peterle CFX 4 February 13, 2014 02:21
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 19:01
Laser Heat Flux & UDF Dominick FLUENT 3 February 12, 2004 15:46
