Pressure inlet definitions
Like Tree1Likes
  • 1 Post By Christian
Old   April 15, 2003, 07:24
Default Pressure inlet definitions
Christian
Hi. I am having difficulties understanding the pressure inlet box. See below a copy of the pressure definitions:
"Gauge Total Pressure sets the gauge total (or stagnation) pressure of the inflow stream. "
and
"Supersonic/Initial Gauge Pressure sets the static pressure on the boundary when the flow becomes (locally) supersonic. It is also used to compute initial values for pressure, temperature, and velocity if the pressure inlet boundary condition is selected for computing initial values."
My problem is the supersonic gauge pressure. The boundary described, is that the inlet boundary or the boundary where the flow becomes supersonic? If it is the latter, I fail to see from where I should know this information. It is this answer I am seeking to calculate using Fluent, not the other way around. And from where should I know the gauge pressure (gauge or stagnation, btw.) when I don't know the velocity.
Help is appreciated.
MUNENDRA SINGH likes this.
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Pressure Inlet Boundary Condition Prasad FLUENT 6 April 9, 2013 21:32
Channel flow: Inlet pressure AND uniform velocity? frmap1 Main CFD Forum 0 April 15, 2010 10:32
about pressure inlet boundary Sastry(CFD Forum) FLUENT 0 February 19, 2007 02:55
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
