April 15, 2003, 04:12 |
engine cylindar flows anyone?
I have been using STAR-CD for simulating in-cylindar engine flows. According to some advertising that I've seen, FLUENT can be use in this application without the need for very time consuming mesh movement programming as is needed for STAR-CD. Has anyone used FLUENT in this application?
Also, how easy is it to generate and mesh the complex geometry of valves and ports in the basic FLUENT software? Any information in this regard would be greatly appreciated. Gareth |
Display Modes | |
SIMPLE pressure correction in compressible flows | Maarten de Jong | Main CFD Forum | 7 | April 30, 2012 03:23 |
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) | kelvinlim | Main CFD Forum | 2 | January 26, 2012 23:19 |
Free surface flows and multiphase flows | Vidar | Main CFD Forum | 0 | September 18, 2008 06:05 |
Can Fluent be used to simulate IC engine flows? | Jimmy Fox | FLUENT | 1 | September 7, 2005 11:35 |
calculating recirculating turbulent flows with k-e | Abhijeet Vaidya | Main CFD Forum | 10 | November 18, 2002 09:21 |
