April 28, 2003, 16:22 |
Courant Number
HI there, i am modeling turbulent flow in a cylinder, my problem is that while solving the solution converges if i reduce the courant number to say 0.001, but this does not predict the actual physical flow, however the solution does not converge for courant number 0.1, but this flow is similar to actually physical phenomena, can anybody please explain, how to choose optimum courant number value and any other means by which i can achieve convergence.
April 29, 2003, 21:39 |
Re: Courant Number
Hi
I apologize for delaying my response until someone else with better understanding reply. However, It seems that nobody wants to lead you question. Therefore allow me to try without having total accuracy of my answer. Courant number defined as the time for a fluid move only a fraction of the grid spacing Äx in a time step (Pope S.B. 2000) k^0.5*del time/del space= 1/20 where k is the turbulent kinetic energy del time is the delta of time de space is the delta of space and 1/20 is the courant number As a result, when you decrease the courant number you indirectly decrease the del time. In this way, the system is able to capture the periodicity of the flow field. I hope this answer helps you Alex Munoz |
Courant number | fireman | FLUENT | 7 | September 11, 2021 12:33 |
IcoFoam unstability, courant number gets large! | vivien | OpenFOAM | 11 | March 9, 2017 04:45 |
LES near wall model & courant number | kasim | CFX | 5 | March 16, 2008 19:23 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Courant number calculation - unsteady flow | Kuba | FLUENT | 0 | November 8, 2005 23:44 |
