Mass Flow Rate Conservation Problem
Old   May 5, 2003, 08:14
Default Mass Flow Rate Conservation Problem
philippe
I simulate the flow of CO2 in a cylinder. After about 500 iterations, using Reports/Fluxes menu, I've got the good value of Mass-Flow rate (specified with mass-flow-inlet BC) i.e. 0.10 kg/s but I've got -0.10 kg/s at the outlet (defined as outflow BC) ! How can I solve this problem ?
Thanks.
Philippe.
Old   May 5, 2003, 09:45
Default Re: Mass Flow Rate Conservation Problem
ap
Maybe I don't understand the problem: you have a cylindrical pipe and 0.10 kg/s of C02 entering it. FLUENT tells you that 0.10 kg/s enter the tube and -0.10 kg/s exit it. Right?
FLUENT considers negative all flows which exit the domain and positive all fluxes entering it. So the value you have at the outlet seems good.
Hi.
Old   May 5, 2003, 10:03
philippe
I think you understand my probleme: I have a negative mass flow rate on the surface which is the outlet of the whole 3D domain.
thank you.
Old   May 5, 2003, 10:11
ap
Ok. As I've already told you, negative values of the mass flow rate at the outlet are not a problem.
Good work
Hi
Old   May 5, 2003, 10:15
philippe
Hi I also have some negative values of static pressure at the outlet surface ?! I would like to be sure that the flow is computed in a good way.
Thanks.
philippe.
Old   May 5, 2003, 10:26
ap
Does FLUENT tells you that you have inverted flow on some cell at the outlet?
Old   May 5, 2003, 10:32
philippe
yes It tells that there is some reversed flows on 20/30 faces on the outlet surface. All the residuals are constant.
mass residuals less than 1.e-03 velocity residual : 1.e-03 energy (thermal model): a little more than 1e-03
Old   May 5, 2003, 11:39
ap
Try to do more iterations. If residuals of energy is over 1e-6, your solution is not considered as a converged one by FLUENT.
Check all boundary conditions.
If you can, try to replace the Outflow boundary condition with a Pressure outlet (you need to know gauge pressure at the outlet). Read the manual about Outflow BC use for more info.
Old   May 5, 2003, 11:43
philippe
thank you !!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Mass flow rate through each cell Babakjingo Main CFD Forum 0 August 21, 2011 03:18
Mass Flow Rate Error jallison FLUENT 1 May 16, 2011 16:22
I have a problem with the sign of mass flow rate Enthalpy behrang2009 FLUENT 0 June 6, 2010 18:02
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
