Heat transfer thro walls
Old   May 12, 2003, 11:44
Default Heat transfer thro walls
Mark
I want fluent to calculate the heat transferred from a flame through a furnace wall to give the outside temperature of the furnace wall. Can fluent do this?
Do you create and mesh the walls in Gambit?
Any advice is greatly appreciated.
Mark.
Old   May 13, 2003, 04:23
Default Re: Heat transfer thro walls
McGregor
Hfi Mark,
The problem you have detailed can be solved using fluent. If you are modelling the problem as a 2D problem then use gambit to generate the geometry and mesh. Otherwise you may find it easier to generate your geometry using a diffent design package for 3D and then exporting it.
Take a look at the user guide for FLUENT 6.1 on the link below. There is a link for the tutorials guide as well which will also be of use to you.
www.psc.edu/general/software/packages/fluent/doc/index.htm
Mcgregor
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
heat transfer at walls ioana CFX 7 May 17, 2004 09:26
