How to deal with this error?
Hello. When I read a Gambit mesh file into fluent, the fluent shows following sentences:
Error: access: unbound variable Error Object: phase-domain? I tried hard to solve these problems, and failed. Is there somebody who could give me some ideas. Thanks a lot. (By the way, the above errors seem not to hinder the model solving, I could get some results although I don't know if these results are right at present) |
Re: How to deal with this error?
I found the problems,it is very weird. Among my boundaries, two B.C. are Wall. If I define them in Gambit, I will meet above problmes when I input the mesh into Fluent. If I just leave them alone, i.e. not define the two walls in Gambit, everything will be O.K. when the mesh is read into Fluent. I still not understand the reason since the default B.C. is wall if not defined.
However, above problems seem not to block you to solve the model. |
