molar concentration marco
Like Tree3Likes
  • 3 Post By Andrew Garrard
Old   May 14, 2003, 12:14
Default molar concentration marco
rookie
In the multispecies model, we can retrieve species mass fraction using C_YI(c, t, i). Does anyone know what is the marco to retrieve specie molar concentration something like C_YI?
Thank you!
Old   May 15, 2003, 08:23
Default Re: molar concentration marco
Andrew Garrard
Old   May 15, 2003, 08:29
Andrew Garrard
I don't know if you can get the UDF to pull out the molar concentration or not. I believe that fluent calculates the mass fraction during the iterative process and then converts this to a molar concentration when requested, for example in a contour plot. You can get your UDF to produce a molar concentration by multiplying the mass fraction by the density and dividing by the molecular weight something like
mol_conc = yi[0] * C_R(c, t) / mw[0];
I don't know if that will you will have to play around with it, but that is how I intend to produce the molar concentration.
Old   June 12, 2003, 20:51
rookie
Hello Andrew,
Your idea works! Thank you a lot.
Rookie
dpm concentration HK FLUENT 0 March 6, 2008 05:44
Concentration Scale Data Interpretation usker Siemens 4 October 23, 2007 20:30
negative species concentration again Andrew Garrard FLUENT 0 March 22, 2005 11:36
initial concentration in multicomponent mixtures isidro Siemens 0 April 26, 2004 07:40
implement the molar concentration eqs? YW Siemens 0 October 1, 2003 14:56
