test cases for Fluent and Gambit
Old   May 20, 2003, 08:53
Default test cases for Fluent and Gambit
Ben
I am a newer for Fluent and Gambit. Since duty reason, recently i started to learn to use Fluent with Gambit as a pre-pocessing tool. I remember that I had ever seen some test cases coming with the Fluent and Gambit softwares in my last institute, they are some .cas or .msh files. However, I can not find this kind of files in our Fluent6 and Gambit in my branch now. Is there anybody who knows where can I get the files from internet.
Thanks Ben --
Old   May 21, 2003, 06:44
Default Re: test cases for Fluent and Gambit
Mcgregor
Hi Ben,
These are the locations of the release notes for both GAMBIT and FLUENT. If you cannot find what you are looking for here, then there are examples that may be of some use.
Good Luck!
http://www.psc.edu/general/software/...mbit/index.htm
http://www.psc.edu/general/software/.../doc/index.htm
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 14:05
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
