Display Error
Old   June 15, 2003, 17:36
Default Display Error
Pat
I'm running Fluent 6.1 on an XP machine, and I keep getting an error message whenever I try to display anything.
Error: Floating point error: divide by zero
Error Object: ( )
The display window then opens up, however it is blank. Does anyone know how to fix this?
Thanks, Pat
Old   June 16, 2003, 07:12
Default Re: Display Error
Stefan
i had one time a graphic problem but it was related to the graphic card when i remember correctly. i could fix it by starting FLUENT with the following command:
C:\Programme\FLUENT.INC\ntbin\ntx86\fluent.exe -driver msw
(which sets the microsoft display driver as far as i understood) maybe it helps... Stefan
Old   June 16, 2003, 10:30
Pat
Stefan,
That was the problem, I needed to specify the driver. Thanks for the help!!
-Pat
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 09:27
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
user defined function cfduser CFX 0 April 29, 2006 10:58
