VOF and Source Term
Old   June 27, 2003, 00:50
Default VOF and Source Term
Mickaël PERRIN
I would like to know if someone succeeds in adding a source term to the vof equations using the multiphase VOF scheme ?
My simulation diverges as soon as there is creation of vapor in the liquid ? any ideas ?
Another question. In the fluent documentation, I read that it is not possible to simulate cavitation with the VOF model due to the techniques of surface tracking. But I don't understand why it is possible to add a source term using the VOF model, and so on, model cavitation by using this source term ??
Thanks,
Best regards.
Mickaël PERRIN
Old   June 27, 2003, 05:01
Default Re: VOF and Source Term
mateus
Hi!
I also never succeded to make a good simulation of cavitation using VoF. I thik ROOZBEH did a lot of work implementing source term in VoF, but I don't know if he had any succes.
Good luck
MATEUS
Old   June 27, 2003, 05:04
Mickaël PERRIN
Thanks, I already contacted him but I didn't have any answer
Old   July 12, 2003, 02:17
roozbeh
Hi; I have a question here! I want to model cavitation with VOF in Fluent some days ago by adding source terms. But I could not even succesfully compile my udf. My sourse terms consist of pressure and volum fraction of water liquid. I will be very happy If I can to even compile it. please guide me.
Old   July 12, 2003, 06:01
Mickaël PERRIN
Hi roozbeh,
I wrote to you some weeks ago at this subject, but I don't have any answers.
I didn't succed in compiling my UDF in Fluent. I have already written and used several UDF, and I think I know the right way to do it, but my differents UDFs to model cavitation using DEFINE_CAVITATION_RATE or DEFINE_SOURCE never get compiled !!!
So I did experiments using interpreted UDF where my UDFs work without any errors... until there was creaiton of vapor, and then the simulation diverged !!
Please take contact by email, I will give you more details.
HELP! adding a mass source to VOF eqn. by UDF??? ROOZBEH FLUENT 5 December 3, 2016 17:53
X-Momentum Source to water pahse in VOF srm206 FLUENT 7 June 22, 2011 20:31
VOF source terms (Momentum and Mass)---How to define them ? cfdiscool FLUENT 0 February 13, 2010 21:10
Equivalent source in VOF model of polymer melting Marcowitz FLUENT 0 February 21, 2008 06:11
Source term for diffusion equation in FLUENT 4.5 Raja Banerjee FLUENT 1 August 30, 2000 23:00
