July 10, 2003, 03:44 |
gambit and gturbo
Hi there, im working with gambit 2.0. if i try to activate the turbo tool, it doesnt work. is gturbo already a part of gambit 2.0 or not? could someone help me? thanks a lot!
July 10, 2003, 04:03 |
Re: gambit and gturbo
HI!
Bad News....You have to pay extra for Gturbo MATEUS |
July 12, 2003, 13:08 |
hi i want to make geometry of francis turbine in gambit. i have gturbo also. what parameters i would required. thanks
July 12, 2003, 13:28 |
You need to write the blade, hub, shroud profiles in a specific format called TUR (*.tur) and import into GAMBIT. Please see the GAMBIT doc for the format of the file.
July 12, 2003, 13:37 |
Hi, In which software i have to write the profile, and what is the method to generate the pofile of hub, shroud, runner. i have geometry file of gamm Francis Turbine. GAMM Francis Turbine Test Case 8 is a Turbine whose geometry files and experimental data is available for researcher so that they can do Numerical analysis and can validate there results with experimental data. I have downloaded its geometry files from web http://lmhwww.epfl.ch/Research/EVA/Gamm.html but these files are in .imh format. I tried to open it in Gambit but failed. May you please guide me in which CAD Software I can open it and Mesh it, so that I can do simulation in Fluent? i will be vey thankful for your help bye
December 21, 2011, 08:18 |
GAMM Francis turbine
#6 | |
I was trying to find on the web the GAMM Francis turbine geometry, but it is not online anymore. Could you send me the geometry of the GAMM (stay & guide vanes, hub & shroud curves, runner blade sections)? Thanks, |
January 9, 2012, 03:26 |
Arslan
i need the geometry files too. How can i reach them. |
Rotor Zone in Gambit | emre | FLUENT | 2 | July 14, 2008 01:03 |
building geometry of an impeller in GAMBIT | PKN | FLUENT | 5 | February 5, 2008 05:24 |
use of Gturbo to make turbine blade | usman | FLUENT | 0 | December 31, 2007 05:47 |
Creatingfan blade profile in GAMBIT | Jenny | FLUENT | 5 | April 28, 2005 05:52 |
Hydro Power Plant in GAMBIT | Mukkarum | FLUENT | 4 | May 19, 2003 07:57 |
