UDF for imposing a BC
Old   July 14, 2003, 01:14
Default UDF for imposing a BC
mahesh
Hi All,
In a problem, I have to get average temperature from an outlet and impose it on another inlet. Following is a UDF, which is not complete, but, i think it is enough to explain my approach. I need your suggestions.
***************************************** # include "udf.h"
real temp=0.0;
DEFINE_ADJUST(get_temp,d) { Thread *t; face_t f;
d = Get_Domain(17); (17 is zone ID of the outlet) temp = F_T(f,t);(will this give me avg. temp at the outlet)
return temp; }
DEFINE_PROFILE(temp_profile,t,i) {
real x[ND_ND];
face_t f;
begin_c_loop(c,t) {
}end_c_loop(c,t)
Old   July 15, 2003, 05:05
Default Re: UDF for imposing a BC
Andrew Garrard
OK, I am not an expert on this, but I think you should consider the following points:
1) Your variables have to be continuous strings, e.g. realTemp or real_temp, but not real temp.
2) You are not actually doing anything with your DEFINE_ADJUST function. If you are defining the profile on the inlet you only need the DEFINE_PROFILE for the inlet.
3) When you use your Get_Domain macro I think you want the Lookup_Thread Macro instead.
4) You are making a face loop when you are not dealing with any faces, also the face loop is not doing anything.
Here is a suggested alternative:
DEFINE_PROFILE(temp_at_inlet, thread_inlet, i) { real temp; /* defining a variable */ Domain *domain = Get_Domain(domainID); /* where domainID is zone ID for domian */ fact_t f_inlet, f_outlet; /* defining faces at inlet and outlet */ Thread *thread_outlet = Lookup_Thread(domain, ThreadID) /* where thread ID is your ID for outlet face thread */
/* you will then want some sort of face loop macro for the averaging of the outlet temp e.g. */ begin_f_loop(f_outlet, thread_outlet) { } end_f_loop(f_outlet, thread_outlet)
and then another f_loop to implement the result into the inlet:
beging_f_loop(f_inlet, thread_outlet) { F_PROFILE(f_inlet, thread_outlet, i) = avg_temp; } end_f_loop(f_inlet, thread_outlet)
I just did this on the fly, but I think it is the right approch you should be using. Check the fluent manuals for the macros that I have used to make sure you use the correct arguments etc...
Old   July 15, 2003, 06:04
mahesh
Hi Andrew,
Thanks a lot. I'll try it out.
Bye, Prasad
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
