outflow boudary condition
Old   July 8, 2003, 06:59
Default outflow boudary condition
damien
hello,
Why is the outflow boudary condition inappropriate for compressible flow ? In my problem, this condition seems good but the fluid is compressible. Could you help me?
Thanks
Old   July 8, 2003, 23:35
Default Re: outflow boudary condition
Neo
If you want to use outflow BC, you must sure that flow is really out of your domain that means no reverse flow happened.
Old   July 15, 2003, 00:13
asif
If I am sure of no reverse flow but at the exit flow is supersonic compressible, is it a right choice in this situation, if no then anyother suggestion, thanks
Old   July 18, 2003, 14:00
KT
No, you can only use pressure outlet for compressible flow simulations.
Old   July 23, 2003, 04:55
asif
In external flow problems like flow over an aerfoil or on a cone usually before hand one is not known of pressure or velocity at the outlets, then how to use that pressure condition (for the case when I want to take outlet condition exactly at the body end)
outflow boundary condition Andy Chen FLOW-3D 10 August 29, 2018 21:50
convective boundary condition for outflow BC Pang Shengyong Main CFD Forum 1 August 24, 2007 17:21
outlet boudary condition for a flow in the pipe Atit CFX 2 November 9, 2004 17:43
outflow boundary condition Guillaume Dulong FLUENT 1 September 13, 2004 05:12
outflow boudary condition in SIMPLE algorithm dallybird Main CFD Forum 0 March 6, 2003 11:55
