HP Turbine boundary Condtions?
Old   July 28, 2003, 13:16
Default HP Turbine boundary Condtions?
Puneet
I have a 3d stator-rotor HPT stage grid. I am not sure whether I am using the correct BC's to study the interaction. Rotor blade : Wall Stator Blade: Wall Rotor Hub: Wall Stator Hub: Wall Rotor Inlet : Pressure Inlet Rotor Outlet: Pressure Outlet Stator Inlet: Pressure Inlet Stator Outlet: Pressure Outlet
Mixing Plane: Stator Outlet- Rotor Inlet
Here is what I am not sure about
Pitchwise boundary of Stator Grid - I am using periodic BC will it be rotational periodic or translational periodic
Pitchwise boundary of Rotor grid: Will it be rotational or translational periodic
Mid Spanwise cutting plane parallel to hub : I am using symmetry but I have a 3d curved profile. Think this is not the one I should be using.
Any help?
Regards
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
Periodic Boundary Condtions in Parallel AndyR FLUENT 0 September 20, 2011 12:06
CFX does not continue Shafiul CFX 10 February 17, 2011 07:57
boundary conditions for a rotating wind turbine problem amoolraina FLUENT 0 December 22, 2010 10:40
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
