DMP problem
Old   July 10, 2003, 21:56
Default DMP problem
zwdi
Dear all, I use DMP model to simulate the dye movement. Surprisingly, I got the result of "evopated=100" state of the dye. The property of the dye is "inert". There is no energy transfer between these two phase(water and dye). I set the density of the dye similar to water. What cause this happen? Any answer will be very appreciated.Thanks. ZWDI
Old   July 10, 2003, 22:47
Default Re: DMP problem
alex
hi
Did you inactive the custom law 1 Inert Heating?
It seems to me that you should do it
Regards
Alex
Old   July 11, 2003, 10:31
kevin
It seems inactiving law 1 doesn't help. There should be some other settings, it is really confusing at this point.
Old   July 11, 2003, 12:32
alex
HI
Could you please check these parameters under:
define>materials>create and change type the name of your material (i.e. dye) type the density constant type the specify heat constant type the thermal condutivity constant
Often times, fluent assumes values for the last two parameters, which could be unappropiate for your case!!
Regards
Alex
Old   July 11, 2003, 20:34
zwdi
Thanks for response. I didn't active energy. And for the material property, only density is needed for inert particles. Seems that I didn't make one error in that point.
Old   July 11, 2003, 21:20
alex
HI
I know that you don't active energy. However, I have found that fluent assumes those values. Evenmore, the code gives you a messege that termal coeeficient was required. If you recognize this message by pressing Ok, Fluent takes some values from a database. Therefore, make sure that fluent store appropiated values.
For setting these values you have to use the text comand not the display comand.
Type
define>material>change then follow the instructions by typing Y or N and the values
Regards
Alex Munoz
Old   July 12, 2003, 08:35
kevin
Hello
Thanks your message. After changing Cp and thermal conductivity, dye is still evaporated. When go to define>materials, it seems that only Cp and thermal conductivity can be changed. Is there any other parameters needed changing? Thanks again.
Old   July 12, 2003, 13:58
Alex Munoz
Hi
At this point, I don't know what is causing this phenomena. I have read simmilar cases before in this forum. I wonder what is your particle diameter, and also which Fluent version are you using.
Please let me know this information!!
Regards
Alex Munoz
Old   July 12, 2003, 17:55
zwdi
I set the particle(dye)diameter is the same as water diameter. And I use Fluent 6.1. Thanks,
Old   July 22, 2003, 14:36
hedonists
I meet the same problem also. Whatever material I use, when particles are below 10nm, it simply evapolate (the temperature is only 300K). This did not happen before, but it becomes so after my university renew the FLUENT licence this April.
Old   July 22, 2003, 14:45
  #11
hedonists
I think it's a problem of Fluent 6.1. It worked well in FLUENT 6.0.
Old   July 31, 2003, 15:49
  #12
kevin
Do you try to solve it with FLUENT 6.o again? I tried it, but it was still evaporated.
Old   August 11, 2003, 22:43
  #13
hedonists
Yes, I tried in 6.0. It worked well
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
