AUTOCAD
Old   September 10, 2003, 05:38
Default AUTOCAD
Boris
Please advise how to export lines and surfaces from AutoCad to Gambit. It seems that AUTOCAD can only export solid (volume) in ACIS format. Thanks
Old   September 10, 2003, 11:24
Default Re: AUTOCAD
Allan Walsh
Gambit can still see vertices and edges created in AutoCad and saved as an ACIS (*.sat) file provided they were there originally. You may have to fool around in Gambit to delete volumes, surfaces, etc.
Alternatively, you could convert the AutoCad file (is it *.dxf?) to an IGES file. You will have to find a translator, such as can be found in the professional version of some of the low end CAD packages - Generic CAD? VersiCAD?. You can find some stand-alone conversion programs on the Web to go from CAD to IGES format. I have tried a few with limited success.
Old   September 12, 2003, 04:49
Default Re: AUTOCAD
Boris
Thank you very much for your reply. I will try as per your suggestion. regards!
[Other] Import autocad into Design modeller lcea ANSYS Meshing & Geometry 1 December 1, 2010 13:15
Import autocad into Design modeller lcea CFX 0 November 30, 2010 04:13
AutoCAD file import enGrid / Netgen deniggo OpenFOAM 1 August 4, 2010 09:38
Civil Engineers and AutoCAD H Main CFD Forum 0 February 26, 2009 18:07
Meshing AutoCAD geometries using ICEM Yuqing CFX 2 November 16, 2006 20:08
